down the road I'll put in oem ones. I have new ones but I do not believe bosch oem. As for tps I will try this reset I did have a bad 02 sensor signal wire from a short. I ran a new wire (signal) from ecu to the 02 sensor. Hmm the wire I used was a maf signal wire, so it had 2 wires on it.. but I only used one I doubt that would matter I used high quality solder. Also specialty Z said it was ok to run at 13-13.5 due to ethanol in fuel they tune for that. If the car goes to 14.6 or whatever they say it will definitely a slight miss at idle, when the z does go there it does develop that. Anyway will definitely try these tricks thank you all!
